• Start
  • News
  • Store
  • Grand California
    • Community
    • VW Grand California knowledge base
    • GC Hacks
    • GC Adventure
  • Gadgets
  • On the Road
    • Tips & Advisor
    • Places to be
    • Road trips
  • WomoWasch.de
  • Contact
  • Newsletter
  • English
    • Deutsch (German)
    • Svenska (Swedish)
    • Polski (Polish)
    • Nederlands (Dutch)
    • Français (French)
    • Español (Spanish)
    • Suomi (Finnish)
    • Dansk (Danish)
    • Italiano (Italian)
    • Norsk bokmål (Norwegian Bokmål)
  • Start
  • News
  • Store
  • Grand California
    • Community
    • GC Hacks
    • GC Adventure
  • Gadgets
  • On the Road
    • Tips & Advisor
    • Places to be
    • Road trips
  • WomoWasch.de
  • Contact
  • Newsletter
  • English
    • Deutsch (German)
    • Svenska (Swedish)
    • Polski (Polish)
    • Français (French)
    • Español (Spanish)
    • Suomi (Finnish)
    • Dansk (Danish)
View Categories
  • Home
  • GrandCali.com
  • Actions / Field measures
  • Roof window recall VW Grand California
2 min read
The 75A3 recall has been in place since the beginning of September. In the last few days, almost all Grand Californias owners have received a letter from Volkswagen stating that due to faulty bonding, the skylight cover may come off completely. The inspection of the windows is mandatory!
Unfortunately, there are once again many assumptions and misrepresentations about the scope of this measure circulating on the Internet. Therefore, here is a detailed execution of the action.
Inhaltsverzeichnis
Toggle
  • Error cause / consequences
    • Error cause
    • Follow
  • Which vehicles are affected
  • What does the Volkswagen partner check?
    • Solution 1
    • Solution 2
  • Photos of the roof hatch with performed action
Error cause / consequences #
Error cause #
In some cases, too little adhesive was used in the window production process. Volkswagen emphasizes at this point that the fault was caused by the supplier.
Follow #
Driving wind can cause up to the complete loss of the skylight cover.
Which vehicles are affected #
Affected models are 600 and 680 built between December 2019 – July 2020 and December 2020 – April 2021.
What does the Volkswagen partner check? #
On the affected vehicles, the bonding of the skylights is checked. Depending on the result, two possible solutions are available.
Solution 1 #
If the bonding is faulty, a new window will be installed by Volkswagen.
Solution 2 #
If the bonding is intact, the window is additionally secured by means of rivets.
Although Volkswagen’s documentation only mentions specific model periods, owners of a Grand California from current model years also receive a request to visit the workshop. This is also the case with our Grand California, which was built in November 2021 and therefore does not actually fall within the timeframe specified by Volkswagen. This appears to be a preventive measure. I’ve read a lot on the subject of rivets, such as people saying, “You must always insist on a new window,” or “Don’t put up with rivets.” Wait a minute at this point!
  1. If you get a new window installed because the bonding is really defective, it will also have rivets, so not only the repaired windows.
  2. The rivets are applied to all vehicles as a preventive measure.
Therefore, the replacement of an intact window does not make sense! The action reads much worse and is made much bigger than it is. Volkswagen emphasizes in the TPI:
Yes, the vehicle can continue to be used until the inspection / repair. However, before driving off, it must be ensured that the crank roof windows are correctly locked and manually checked. The skylight in the wet room is not affected.
Photos of the roof hatch with performed action #
Wie gefällt dir dieser Beitrag ?
Artikel teilen :
  • Facebook
  • X
  • LinkedIn
  • Pinterest
Updated on 28. December 2022
Grand California Field Measure 06F4 – Odor InteriorService task 23DT – Update engine control unit
Powered by BetterDocs
Leave a Reply Cancel reply
Your email address will not be published. Required fields are marked *
Table of Contents
    • Error cause
    • Follow
    • Solution 1
    • Solution 2
Instagram
Check out our latest posts on Instagram.
Blogged with love from around the world
Facebook-f Instagram Telegram
Sign up for our Newsletter on!
  • Imprint
  • Privacy policy
  • Contact
  • Imprint
  • Privacy policy
  • Contact
© ZM Media
